I’ve connected pitch and gate from an elektron analog keys. This used to work fine and enable me to trigger the Voyager from the sequencer of the analog keys. Since today however, the Voyager seems unable to receive any gate signal and the notes keep sustaining. Pitch still works fine from the analog keys.
It’s probably completely unrelated, but I recently started using the BNC gooseneck lamp.
Is there a way to verify if the ENV Gate input is broken? Tried using a different cable, different cv output from the AK, a foot switch, but that also did not stop the signal from sustaining.
Thank you very much sir!
Weird thing is: all the settings were like you mentioned. Selecting different ENV inputs and then back to ENV Gate src and de- and reselecting local control seemed to fix it though
