Editor + Ableton Live = additional midi events/sysex
0.9.28 + 1.1.13 - hardware/software as per signature
This is the setup:
add MIDI track
add external instrument device
midi to = sub 37
audio from = audio interface that sub 37 is connected to
add sub 37 editor after the external instrument device
Changing a preset in the editor librarian by double clicking the preset in the rightmost pane creates a midi loop:
12:01:57.414 To Moog Sub 37 Control 1 Bank Select 0
12:01:57.414 To Moog Sub 37 Control 1 Bank Select (fine) 0
12:01:57.414 To Moog Sub 37 Program 1 54
12:01:57.435 From Moog Sub 37 SysEx Moog Music 756 bytes F0 04
12:01:58.047 From Moog Sub 37 Program 1 54
12:01:58.073 To Moog Sub 37 Program 1 54
12:01:58.091 From Moog Sub 37 SysEx Moog Music 756 bytes F0 04
12:01:58.728 From Moog Sub 37 Program 1 54
12:01:58.754 To Moog Sub 37 Program 1 54
12:01:58.772 From Moog Sub 37 SysEx Moog Music 756 bytes F0 04
12:01:59.351 From Moog Sub 37 Program 1 54
12:01:59.377 To Moog Sub 37 Program 1 54
12:01:59.397 From Moog Sub 37 SysEx Moog Music 756 bytes F0 04
12:01:59.993 From Moog Sub 37 Program 1 54
12:02:00.019 To Moog Sub 37 Program 1 54
and so on until I press a note on the sub 37 - which generates these events:
12:02:07.038 From Moog Sub 37 Note On 1 D2 120
12:02:07.040 From Moog Sub 37 Note Off 1 D2 120
12:02:07.041 From Moog Sub 37 Program 1 54
12:02:07.063 To Moog Sub 37 Note On 1 D2 120
12:02:07.066 To Moog Sub 37 Note Off 1 D2 120
12:02:07.067 To Moog Sub 37 Program 1 54
on pressing every subsequent note it is sending out 756 bytes of sysex and additional note on/off program events eg this is from a single note press:
12:03:46.493 From Moog Sub 37 SysEx Moog Music 756 bytes F0 04
12:03:47.096 From Moog Sub 37 Note On 1 D3 123
12:03:47.098 From Moog Sub 37 Note Off 1 D3 123
12:03:47.101 From Moog Sub 37 Note On 1 D3 123
12:03:47.103 From Moog Sub 37 Note Off 1 D3 123
12:03:47.105 From Moog Sub 37 Program 1 54
12:03:47.122 To Moog Sub 37 Note On 1 D3 123
12:03:47.124 To Moog Sub 37 Note Off 1 D3 123
12:03:47.127 To Moog Sub 37 Note On 1 D3 123
12:03:47.129 To Moog Sub 37 Note Off 1 D3 123
12:03:47.131 To Moog Sub 37 Program 1 54
it does this until I change the “midi to” in ableton’s external instrument device to something else (or de-activating the external instrument) and play a note on the sub 37 - then it clears to the expected 4 events per note press (as ableton’s external instrument device sends the incoming midi to the target external midi hardware - which happens to be the same device in this case):
12:06:13.709 From Moog Sub 37 Note On 1 D2 27
12:06:13.735 To Moog Sub 37 Note On 1 D2 27
12:06:13.858 From Moog Sub 37 Note Off 1 D2 27
12:06:13.884 To Moog Sub 37 Note Off 1 D2 27
Same for me, when changing preset (from editor or from the Sub37) and the editor is open (DAW isn’t), the Sub37 send midi messages until i press a key :
Pressing a key don’t stop this behavior any time …
Firmware : 1.1.13
Editor : 0.9.28 (standalone) on OS X El Capitan v10.11.2
Thanks for the detailed reports. We know about this and it’s surely on the list of issues to be targeted.
Gil.
