flt sip seems unresponsive as a mod destination
Hi Iain, thanks for reporting. Will you please add the following to each report:
- On which platform you see the issue
- What are the steps used to reproduce the issue
- What’s the expected behavior
This will help us understand. Thanks!
3.1 GHz iMac OSX 10.11.2
Sub 37 firmware 1.14
attached setup
expected cycling filter slopes
may be my error as Sub 37 reports sources and destinations correctly
iain
slp.tiff (1.44 MB)
If I try to set it from hardware I can make Filter Slope modulate. I’m afraid I need more information.
Hi Gil,
the attached was on the editor 9.31, I have checked mod 2 src and destination (SIN LFO and FLT SLP) on my Sub 37 controllers menu and they are showing the same (bottom of attachment). Unfortunately, being disabled, I find setting them up by menu buttons on the Sub 37 is physically difficult, which is where I hoped for the editor’s aid. I’ll try and get someone’'s help later to do the Sub 37 setup later. Hope I;m not wasting your time.
Iain
how do I export a .syx file to send you my setup?
manually setting on Sub 37 mod source to sine lfo DOES work but editor settings are ignored, destinations work
