edit synth then rename on editor
Creating a sound on the synth with the editor open, then renaming it on the editor results in Init Preset.. i.e. all edits are lost. Except you do have the new name :slight_smile:
Couldn’t reproduce it, can you please specify:
  • if you used Standalone or plugin (and under which DAW) ?
  • What method you used to rename it ? From top menu ? Hardware Preset on Librarian ?
Using OSX in standalone mode. I’m renaming on the hardware preset panel in the librarian.
I was having difficulty reproducing it until I renamed using a right click (without using alt). Its not very easy as right clicking on its own doesn’t always work, which is probably why I couldn’t reproduce it.
Its odd behaviour in that sometimes it is a simple and easy right click, and other times its not possible without a few attempts.
Using the right click alone (no alt) brings up a small ‘rename’ dialog that doesn’t appear when using the left click + alt method, so possibly a remnant from a previous version.
Thanks. Still not sure how to recreate the problem. I have followed your description and it works right here.
Weird.. whatever I do I can’t reproduce it either today!!.. It was definitely doing it yesterday :wink:
:wink:
Let us know if see this again at some point !
