Duophonic not working
Did the firmware update. Activated the duophonic function. Did not work. Not surprised.
Anyone out there with a solution or the same experience?
Same issue but no method.
for me it seems to work in some instances, but not in others. unclear why.
Mine seems to work, are you using a patch that uses two oscillators because it’s paraphonic really.
what do u mean here ? cause using two oscillators doesn’t mean it s duophonic perse
(most of the presets use 2 oscillators and a monophonic)
You must have two oscillators in use for the paraphonic to work, each voice uses one oscillator. It works better when both oscillators are the same waveform and same octave.
again, there are always two oscillators at work: u cannot switch them off, only mute them sync them or modulate them. So how do u engage duophonic/paraphonic mode?
Still it’s paraphonic. You only have 3 (OSC 1, Sub OSC and noise) and 1 (OSC 2) voices per key. Also the filter and envelopes share only one path. Duophonic would mean that each key has its own section.
You activate the mode with holding the Sync button under the oscillators. Would be super nice to have a manual and release notes for that update.
thanks I know that. my question was not regarded para duo phonic.
thanks for the shortcut! indeed sloppy they did not update the manual
Yes you have 2 oscillators always but the volume knobs in the mixer section must be up so that both oscillators are being used.
thanks but that also applies in monophonic mode, it s a bout triggering the notes separate or together not hearing them seperatre or together
