The Moog Voyager is notorious for not conforming to strict 1v/Oct scaling. On my Old School, it was around 1.030 volts per octave (actually measured at the pitch CV output).
Even Moog Music itself acknowledges this fact in its MP-201 spec:
“CV SCALE: This is where you adjust the CV output so that the thing you’re controlling will track pitch correctly. Not everything is scaled to exactly 1V per octave (example: Moog MF102 Ring Mod tends to be around 0.7 V/Octave) - you can choose any scale in the range 0.667 V/Octave to 1.333 V/Octave.”
So, any device that is locked into sending 1 V/Octave probably won’t pitch track properly on the XL.
The Voyager tracks internally at 0.935V/oct. If you add the VX-351, there is a part to add inside the Voyager so you can get 1V/oct at the 351 CV outputs.
It’s a weird scale because of the resolution of the DAC on the analog board.
Thanks for replies, in regards to the vx-351, I essentially have one of these built into the XL along with the CP-251 module, do you know if I can get the XL to spit out and except 1v/oct? anything I can tweak?
And as far as playing my XL with the micromac, I will not hurt any thing on the voyager or micromac patching wise with these differences?
Is there a workaround for getting the two synths to play nicely together?
I am also considering the dektop module, which I will be able to play with midi so scaling might be to much for a problem, though I was hoping to use my XL as a modulation source and vice versa.
Not sure if it helps anybody (there is discussion here about sending V/Oct as well as calibrating the Analog board for V/Octave coming into a Voyager or Old School) but I had my Old School mod’ed last year and Moog Support essentially pulled R47 (which is a 100K resistor from the factory) and replaced it with a 90K resistor and a pot/trimmer, then calibrated it to precisely 1V per octave.
This is to address the incoming pitch CV jack and is required if driven by a CV keyboard such as a Minibrute, or a sequencer, etc.
Since the Voyager and Old School have the same Analog board in common, I would assume the same would apply and that the Voyager does not have any software controls to adjust the voltage.
I have a Little Phatty Tribute also and I’ve been told that these original synths had a pot for the incoming Pitch CV, while the Stage and Stage II do not. I have not confirmed this, however; but if you find the point on the board, there certainly is a work-around.
Not sure why you would need to use the XL as modulation source… In the Micromac D you will already have 3 analog LFOs and 2 (I think) in the Kenton MIDI unit.
Btw, i understand the R version could also have the 2 extra analog LFOs as an add on unit that Ken is planning. But then of course you will not get the Kenton module with the MIDI and other extra goodies.
BHC303, did you ever try using your XL Pitch ins and outs with any other oscillators? I’m interested in using mine with some modules, either eurorack types or dotcom, and am wondering how successful I will be with the tracking. . .
I have tried feeding the pitch and gate from my Minibute to my VoyagerXL and I can’t get it to track accurately. I blamed the Minibrute at first but after reading through this thread I am not so sure.
Does anyone know of a good way to test the cv tracking with a voltage meter? I would really like to figure out which synth needs to be tweaked, if not both.
Those two instrument both having MIDI capabilities, you should use that in order for them to track each other precisely. Because, as you may know or not, using the CV out and CV in of any two analog synths is extremely difficult to have them both track each other exactly. Especially when you consider that for every additional volt of the Control Voltage the pitch goes up one full octave !
That is precisely why MIDI was created by Dave Smith. Because prior to that, it was very difficult, even impossible sometimes, to control analog synths so they would play in tune with each other.
To answer your question: does the Voyager track 1V/Oct, the answer is…maybe. Depending on your particular unit. My Old School did NOT track at 1V/Oct. But my EB did. But my friend’s Select doesn’t…
BTW, the standard 1V/Oct is exactly that: a standard. All machines should have their oscillators track the CV precisely, resulting in an increase of exactly one octave higher in pitch with each additional volt. However, it is rather difficult to have analog circuits behave precisely like that. So, compromises are often made with internal stretch tuning to offer a decent amount of range before oscillators go out of tune.
BTW, you do NOT want to start tweaking the internal tuning of either of those machines. Unless they’re really not tracking well on their own.
You can measure the dc voltage at the CV out of both machines. It should result in an increase of 1 volt for each higher octave played on their keyboard.
According to Moog, my XL should track @ 1V/Oct from the factory, there is support to calibrate this if it it is not tracking correctly via moog support.
Not sure exactly what is carried out here…
I cannot speak for regular voyagers as mine is an XL (and believe it has the VX-351 trim calibration built into it as mentioned by MC)
I cant test it now as my studio is in bits as I am selling gear…
But yes midi will be the best bet, silent way and volta can also calibrate and do this job if you are using your modular and don’t have a midi to CV converter.
A friend of mine had there minibrute delivered not calibrated correctly… I believe sonic state have video on how to calibrate it if my memory serves me well… its like the first minibrute vid they did I think. got it sorted pretty quick.
So, after being assured by Perry at Moog that the XL was indeed 1V/octave on both the in and out, I went ahead and built up a small eurorack modular for use with the XL. I now have a makenoise DPO and a Malekko Wiard Oscillator tracking beautifully from the XL’s pitch out: mixing that with the 3 oscillators from the XL, and it sounds awesome. I get 5 octaves, basically, which is good enough for me! I also am using the makenoise Rene for my sequencer, and I have the quantized CV multed out to the 3 eurorack oscillators and the 3 XL oscillators, and I also get 5 octaves that way
When I first tried this out, it was not working so well. I had not yet bought the wiard Oscillator, and, between the DPO and the XL, I assumed the XL just needed a bit of adjusting, since there is a lot of speculation about the 1V/octaveness of it. . . I got instructions from Perry on how to adjust the trim for the CV-out on the voyager. This fixed the problem of getting the DPO to track along with the Voyager Osc’s, but, when I got the Wiard, I realized that the wiard was now off. I double checked things and noticed that the Wiard and Rene were scaled the same, but the DPO (and now the XL) were slightly different now. So, I recalibrated the XL to work with the Wiard, then I adjusted the trim pots on the DPO. Problem solved! Then, to top it off, I adjusted the pitch input trimpot on the XL, which made it so that everything followed the Rene perfectly (before, I had to use the XL’s attenuator to make it follow the quantized CV correctly). Now, all I have to do is mult the pitch from either the rene or the XL and send it to the rest of the sound sources, and I’m in business. No attenuation or other scaling is necessary. I used this in my performance at “switched on” last week in a song where I had a fun Rene sequence going to all the oscillators which were then filtered or modulated in different ways. Flippin’ sweet!
I agree that midi is a good way to go, and I use midi a lot for different things. . . there is something that feels really immediate about the CV, though, so I prefer to go that route sometimes; )
Here’s the calibration proceedure for the pitch out on the XL. Be warned, doing this MIGHT VOID YOUR WARRANTY, so I would check with moog first if yours hasn’t expired yet. I am not an engineer or anything, and I thought it was totally easy to do. I’d say just be certain to stay clear of touching anything that is not mentioned in these instructions:
*Lift the front panel and place a small stack of books (~2-2.5” high) underneath.
*Remove the 7 screws located at the top of the panel and carefully lower the plate
*Locate VR100 on the back of the modular board (11-461). This is the keyboard CV calibration.
*Play an E3 (0v) and run the keyboard CV out to a piece of modular gear. Use the Fine Tune knob to get this in tune.
*Now play an E5 and look at the tuning on the synth being controlled. Adjust VR100 until you get a perfect 2 octave interval.
*Check other E notes along the keyboard to insure proper scaling (it is common for notes in the outer registers to be a bit out of tune with CV).
*Close the back panel and reinsert the 7 screws.
Yep, it only affects the CV out. I asked Perry the same question after he sent the info. As far as I can tell, there is no change whatsoever to the way the keyboard affects the oscillators, and Perry confirmed that that was the case. I noticed that there is a similar trim labelled “CV in” and I used it to calibrate the way the CV in tracks an external sequencer.
