If you have patch cables plugged into the Matriarch, can you put it into the Moog soft case with them still in or will it not fit and/or mess up the input jacks?
It’s possible to mash down the patch cables enough to close the case, but I would not recommend it. The Moog soft case is a snug fit. The flex part of the cables are forced to bend at a sharp 90 degrees at the end of the rigid plugs. So, I’m concerned that the cables could break or—worse—develop intermittent shorts.
Ok, Thanks. I assumed as such. I wonder if it would be worthwhile to invest in right angle patch cables so you could put it in the case without having to unplug everything.
