Distortion pedal for sub37
Hello,
can you recommend some distortion pedal for sub37 which can achieve the similar distortion as LP?
I am planning to connect it btw sub37 and delay. The other possibility is to connect the output of the pedal to the feedback input of the sub37.
Thank you in advance.
Frank
Not really a pedal and maybe a bit expensive but Sherman Filterbank + Sub 37 = Awesome.
Bass Big Muff Pi Deluxe.
It has a blend knob to mix the dry signal, a gate to limit the hum, and a crossover. The crossover will send the distortion through a high pass, and the dry signal through a low pass, each with its own cutoff. And the crossover is activated by its own switch.
It’s like $130. It’s crazy how flexible it is, especially for something from the Muff lineup.
AND. it has a buffered dry output, which you can send back into the audio input to further drive the filter.
Haha - that pedal looks awesome actually. Might get one!
Is the Big muff symmetrical clipping? As I know the big difference btw the Sub 37 and LP is that the Sub 37 is sym clipping and the LP is asymm clipping. Do you have any sound samples using Big Muff with synth? Does it have similar distortion as LP?
Anyhow it looks interesting.
I’m not sure how close it is to to the little phatty filter overdrive, because I don’t have one. It is very similar in some settings to the multi drive on my sub37, but not exactly the same. It’s great, but it’s not exactly the same. Nothing will be.
The question about symmetric or asymmetric clipping yielded this informative google result:
http://www.geofex.com/effxfaq/distn101.htm
Very interesting, but since I don’t have lots of experience listening critically to overdrive/distortion/fuzz effects it’s not so useful to me.
I did pick up an EHX bass deluxe big muff pi for my sub37 the other day and it sounds, … fuzzy. Twiddling the crossover knobs etc is again, interesting, but I find defeating all of the bells and whistles give the most pleasing result, as most of it just rolls off the effect on the bass to allow more of a clean tone underneath. Of course I like the clean tone, but don’t find limiting the fuzz to the top end that nice.
Funny the article above calls out the approach used in the big muff pi specifically as “Widely held to be an example of what is wrong with transistors for musical instruments” hah!
I really like the Malekko Diabolik Bass Fuzz pedal.
For distorting my Sub 37, I use nothing as often as the Waldorf 2-Pole Filter.
Fantastic distortion possibilities with unique characters: Overdriving the input stage, rectifier, and post-filter overdrive.
Nothing else squeezes the juice from the Sub 37 as sweet as the 2-Pole :slight_smile:
Small addition: I’ve written a very short article about the 2-Pole on the Sub 37 Cookbook:
http://sub37cookbook.frankwilleke.de/gear/waldorf-2-pole-analog-filter/
Jumped into this one late and I don’t know if you’ve made a choice already but I’m throwing in another vote for the Bass Big Muff PI Deluxe. It is extremely flexible and I’ve been able to create some awesome sounds utilizing its unique distortion and filtering capabilities.
At the moment no decision. I have been on holiday during last two weeks. Originally I was thinking about BOSS DS1 or SD1. Is there any comparison btw. DS1, SD1 and Big Buff? Is it worth the extra money comparing to the Boss pedals?
Frank
I have checked the link to Waldorf 2-pole and it seems very interesting too. Do you have some more sound samples (leads) which can be produced combined with sub 37?
Frank
I don’t have any examples at hand currently, but I’ll be in the studio tonight, maybe I find the time for some more sound examples.
Can’t promise it, though.
DS1 is distortion rather than fuzz. Personally I hate the DS1 though some people love it. I’d have thought it’s more suited to guitar.
That Waldorf 2-pole looks really interesting - kind of like a mini Sherman Filterbank. I’d go for one of those!
There is a newer filter effect box on the market based on the polivoks filter. There was a blurb about it on sonic state a month or two ago. I have the polivoks filter in my modular and it distorts all on its own, beautifully. That might be an interesting option. It’s hard to find a transparent overdrive that can handle the tonal range of a synth.
I have added six additional sound demos to the Waldorf 2-Pole article. All dry recordings with only the Sub 37 and the 2-Pole in the signal chain.
Specifically demonstrated are the different filter types, the distortion possibilities, the threshold-based envelope trigger, and the LFO, as well as self-oscillation of the filter.
Alas, the sound quality of 16-Bit 44.1Khz MP3 with 256 KBit in deed takes away some of the rich harmonic content. The raw uncompressed recordings did sound a little better.
Btw, the 2-Pole can be really awesome on beats, too :slight_smile:
Could you do a demo video or audio of the sub 37, minitaur, and/or voyager with the deluxe bass muff?
Thank you for doing this - it sounds great!
I have the Bass Big Muff (as I said before) and like it fine. And the Waldorf sounds even better. But this thing is pretty awesome:
http://www.dwarfcraft.com/silver-rose-v2.html
