digital noise and stage edition
What’s about the well known noise of the tribute, which is getting into the filter with high volumes or distortion levels?
I have read that this could be fixed by firmware but I think it’s more a hardware issue.
Is it fixed with the stage edition ?
greetings
Volker
Copied from my post in another thread…
I’m happy to report that the annoying keyboard scanning noise has been squelched with the release of the Stage Edition. No longer are there digital artifacts in the audio path even when applying a hefty dose of overload which was my main gripe with the TE.
I believe it was more of a hardware issue in the Tribute.
This issue has been fixed with the Tribute as well with the OS update. Switching the EGR Matrix to OFF will totally eliminate the sound! I think this was accomplished by some very, very clever programming in the new OS. Hats off to the Moog crew!!! The Tribute now sound as good as it should!
But then we live without EGR controls. Can it be resolved w/o taking the EGR section out of the mix? What if another issue comes up that can be fixed by only running one oscillator? :open_mouth:
You can compensate somewhat for the loss of the egr buttons by mapping any of the pots to an egr function.
incredible, i can´t believe this is true, soooooo, what we paid for? wood panels? is here somebody from moog who can tell us? so… no 2mod destination, ok, but we have to take of egr to kill the noise! some more issues???
I had a big talk with the engineers here… the summary of which is that there are some very good reasons to appreciate the Tribute Edition, and some things it has that the Stage does not. They are two different instruments. I predict that the Tribute will become highly sought after in time, and not just for its relative rarity.
One thing I can tell you about is that the Tribute has more RAC (real analogue control) functions… almost every panel function you can assign to a knob is RAC-enabled, meaning that the analogue pot is switched directly into the relevant circuit when active, for total, hands-on analogue control. On the Stage, to cut costs there are several panel functions which do not use RAC.
I don’t have a complete list, this is off the top of my head. Don’t worry Stage folks, the filter section is all RAC-enabled except for Filter KB Amount. I think it’s the EG section that is not RAC except for Sustain level, and some of the oscillator functions also…
anyway I wish I could go into more detail but the product is so new, I really can’t discuss what it is doing on a deep architecture/circuitry level… but I am serious when I say, the Stage and Tribute are two different instruments, both of them have their strengths… and each of them offer unique and good things which the other does not have. I hope that all LP owners will appreciate their synths… they each have so much to love! :slight_smile:
The egr matrix off function works but isnt ideal…
Just to clarify, despite some features not being RAC enabled, they will still be analog right? (not software driven)
sorry for the confusion - YES everything in the signal path, and the envelopes, are pure juicy analogue. RAC only refers to how the knobs on the panel control those analogue circuits. With a RAC-enabled control, the potentiometer is switched directly into the analogue circuit, so that you have direct control. If RAC is not enabled, then the potentiometer is scanned (like on the Voyager) and this is then used to create a control voltage for the circuit. In either case, you are still ultimately tweaking on an analogue circuit…
I haven’t had my coffee yet, so I hope this makes sense.
Another big reason why the Tribute rocks: You have analog trim pots all over the board inside, so you can calibrate the thing manually… I know we have automatic note calibration now which is cool, but for just for an example the envelope times… these can be calibrated by hand and adjusted to perfection on the Tribute edition. There are many fewer trim pots inside the Stage Edition (they’re expensive!) so there is less you can tweak & fine-tune, if you’re into that. Just another example of something that will I think be praised and desired about the Tribute Edition in the future. :slight_smile:
Amos
Sorry, but why should one prefer a manuell calibration over an automatic calibration ?
I think most people are players rather than technicians who are able to open the phatty for servicing :question:
I am disappointed by the fact that I bought a moog especially for the analog sound quality and have to deal with DIGITAL noise in a lot of presets I have made.
To switch of the envelope controls in a players keyboard is a joke.
Volker
did you just call your lp a keyboard?
hahaha
I always feel guilty calling my LP a keyboard… :laughing:
:smiley: Sorry, this is not my native language.
A Keyboard is most likely something like a casio or so.
Nevertheless I think you know what I mean.
greetings
Volker
Don’t be sorry.
Your english is propably better then most members german, dutch, russian, or whatever your native language is.
:sunglasses:
I’m just teasing you…you can call it whatever you want :smiley:
What is this DIGITAL NOISE issue with the Trib? I have one and I just updated the os to 1.03.
If you look back a-ways in the forum, before all the sturm und drang of the 2nd mod destination, you’ll find complaints about digital artifacts. You’ll hear them when you turn the osc level for both oscillators all the way down. Next turn the cutoff all the way up. Now press keys while adding overload and you’ll hear them clearly. With both oscillators at zero, you shouldn’t hear anything, but there is digital interference creeping into the signal path, kind of like a cheap sound card.
yeah i hear it but its way down in the mud it will make a nice intro if i amp it a bit :slight_smile:
I noticed Amos metioning that the Stage Edition no longer has RAC control for the Filter or Amp EGs. It took me a second to put two and two together, but now I realise that they figured the only way they were going to get rid of this noise was to completely disconnected analog control of the EG section. Hence the ability to turn off or on direct analog control in the new OS for the Trib. Now I’m rather happy to have a Tribute where I can decide to have analog control of the EG or not. It’s rather ironic that the first recording I made with my LPTE used real time knob movements of the Filter Decay parameter.
What I would love is if the EG Matrix On/Off can be assigned individually for each patch. Most of the time I don’t make real time EG adjustments, so I’d like the better signal/noise ratio. But for those occasions where I do make those changes, I’d much prefer to do it analog. I’m seeing how long I can go on my LP without ever needing midi control of any parameter. I love going analog as much as possible. So hopefully, for the next OS update, I’d love to see EG Matrix moved to the Patch menu.
