- in librarian view, select all hardware presets in the right pane
- hold “ctrl” and deselect some
- program crashes or needs long time
Hi, works fine and fast here. Are you using Windows 7 ? we will post 0.9.29 soon. Will you be able to check again once installed ?
Thanks !
i can confirm this.. in win7
Regards Luloop
OK I reported this. We may ask for more details so please follow. Thanks !
Hello,
I’m Salvator, the programmer for the Sub37 Editor, and have a couple of questions in order to isolate the problem :
- Is the bug still there if only selecting 32 or 64 presets ?
- How much times does it hangs when this happen ?
- Does that time change depending on the number of selected presets ?
- Do it also happen on the center pane ?
- Still happen when hardware is disconnected ?
Feel free to reach me by pm, to manage a live screen sharing support session (teamviewer etc…)
Thanks,
Salvator
- When selecting 32 or 64 presets, There is no problem.
- Time is about 6 sec by selecting the whole bank.
- Yes selecting all presets it takes about 6 sec. Selecting 32 or 64 presets, time is about 2 sec.
- It happens only on the center pane.
- Yes when hardware is disconnected the problem is also there.
I found out that it happens when you select All the presets in the center pane.
I copy all the hardware presets to the user bank and select them all.
Then delete them. and then it happens.
trying 5 times…2 times with the problem.
Regards Luloop
Hi Salvator,
The problem is still here. Also with the new Firmware v1.1.14.
It would be nice, when more Beta Tester, trying this phenomenon.
Regards Luloop
Hi Moog
Everything is running smoothly …This makes my day.
Editor 0.9.30.
Greetings from Bernhard
Warm regards Luloop
Thanks Luloop. Please keep and open eye on this and let us know if seen again. Much appreciated !
