Dead audio output?
Hi, I have Little Phatty Tribute #0095 and I purchased it off of a third party. It was working fine and still does except suddenly the audio output stopped working. The head phone jack works fine and all the controls are normal. I try the output on/off switch and it turns on and off but I get no audio from the output jack either way. I have it hooked directly to a working krk rokit 5 Monitor. I tried the system restore and the reboot option from the menu also. Is the output jack actually dead, or could it be a software issue? Any help is much appreciated! Great forum here by the way guys, glad I finally joined.
Also the OS is version 2.10t
Is there anything hooked up to the midi in jack?
If so (I have had this happen), the LP might be receiving a volume CC and muting. I hope it is nothing serious. Contacting moog support has always been helpful when I have had issues. They answer the phone.
well, I got home from work a little while ago and turned it back on after being off all night. It outputs to the main speakers for around 10 seconds and then cuts out, but the headphone jack still plays however. If i turn it off for about 3 minutes and then turn it back on it plays to the speakers for about 10 seconds again before just cutting to only the headphones. Very strange.
It appears like there must be some hardware problem or wiring problem preventing output. Else its not likely to have no audio output.
