Crash in Ableton Live 32 bit OSX
When I start the editor without turning my Sub37 (firmware 1.1.14) on, it starts good but after turning my Sub 37 on, the plugin (0.9.30) and Live crash.
The standalone editor shows me a forever spinning beachball (I need to forced quit it).
Before the last firmware and editor updates everything worked fine
I installed editor version 0.9.29 and everything works fine. After reinstalling 0.9.30, crashes again.
Grtz,
Toine
As Amos already noted, on 0.9.30 VST component is known to cause crash (will be fixed to next version). The standalone should load though… What if you don’t try to load it as VST first ? does it still hang ?
You’re right, sorry, didn’t read about problems regarding the VST, starting the standalone without starting the VST first works fine, thanks.
Toine
Just read this too… Ableton Live Suite 9.5 32 bit and VST 0.9.30 definitely don’t get on :smiley: .. I’ll try a roll back to 0.9.29
R.
Well, actually the VST crash was seen on Windows, and must happened due to changes done on latest version, works ok for me here now. VST on Ableton under OSX must have been unstable with previous versions as well.
