Hello everyone!
There is a strange behavior of my Moog Sub 37 which is quite annoying: After some time of usage the volume of its output suddenly decreases and some kind of weird crackling/scraping sets in in the background. Is there anything I cans do to fix this?
Thanks in advance!
It seemingly only affects the headphone output, trying out a different 6,3mm to 3,5mm jack now. I will let you now if the problem disappears.
Alas, it still happens. Did anyone else encounter an issue similar to this?
Contact Moog and let them know you are having issues.
Thanks, I will do that.
Several people had that issue: it was discussed in another post. I had mine repaired: they changed the board supporting the headphones out. Cheers
That’s great to hear, thank you! Still waiting for the Moog support to answer tho.
