I saw someone’s patch chart for a modular recently and saw that an audio signal was being sent from the minus output of the CP3 into a 904a…when ever I tried this all I get is a click…no audio. I had always assumed the minus output was for control voltage etc and not audio signals.
No matter how I adjust I do not get any audio signals from the minus output…can anyone enlighten ?
You must have a faulty mixer… it should sound exactly the same, but be visually (on a 'scope) 180 degrees out of phase with the positive output.
Cheers
Tom
Thanks …Oh no ! I made four clones a while back and was sure they were spot on…I have to take another look…so I get DC from the minus outputs but no audio ?? I wonder if it’s anything to do with the trimmer setting ? As there is no direction for the trimmer setting I’ve left them all at half way…I will tinker about and see what happens …
Which ones did you build clones of… the transistor CP3 mixer or the op-amp CP3A mixer…?
Tom
Tom…it’s the transistor version ..funny, I’ve done some tests and found I do get audio signals from the minus output …but only when the master volume pot is set to roughly half way …any further either way and the signal disappears …also it’s only about 50% of the positive output.
I probably have a wiring or component problem somewhere so the only thing to do is take a CP3 module out and fully test it.
The trimmer is there ( I think) to balance the volumes of plus and minus.
Sounds like you got some phase cancellation going on there..!?
When I built my two IC versions I found that the two ‘output offset’ trimmers didn’t actually do all that much… the transistor circuit is a lit simpler. Do you have a 'scope to check what’s going on in there, and are all four of your builds the same…?
Tom
Yes, I built them last year and so far there’s been no problems until I saw someone taking audio from the minus output, then when I tried it I got nothing , only DC signals went thru.
I will take one out tonight and examine it , as I say it’s probably a component that’s wrong or maybe wrong connections…
I’ll post up when I find the problem.
