Have a couple of old CP-251 with the red jacks. They have power supply inputs on the topside and bottom. Just got one off e-bay which is the new model without the red rings. Does not have a power supply on the bottom, and has a plastic plug in the back panel where the supply jack should be. Was this changed with the newer models, or was this somehow modified by a previous owner? If it was changed, is there a way to get the part for the power supply to be in the back? Probably will rack this like the other units and I use the back supplies for them in the rack.
I had the older one and you could unplug it from the board and move it over to the other hole (taking out the plug on the back and putting the plug on the top where the jack was.
Or is your power jack or back jack hole missing completely? I bet Moog would sell you just that part if you explained your situtation. If the hole is missing, just make a new hole (close enough so the jack will reach).
If it’s like the old CP-251, the top DC inlet is attached to the PCB inside. You’d be better off getting a second inlet and wiring it in as mentioned above.
Yeah I got one a couple months ago and I damn near broke my thumb trying to get that plastic cap off. Opened it up and sure enough there’s nothing underneath. Bummer, I have it mounted vertically so a bottom plug would be nice.
Well it is quite easy to take that cap off from the other side, without using your nail. I did that and moved the plug to the bottom easily, it works like a charm mounted vertically on my rack along with the VX-351
I just relocated the power on mine to the back of the panel…
The connector that plugs into the pcb had a dab of hot glue to keep it connected. Do I need to re-hot glue that together? It just sits in my studio. Not gigging with it.
