ok we’ve already established that the 251 handles audio as well as CV. my question is
what happens when you use the inverter, in the mixer section, on audio?
i assume that it inverts the waveform of the audio so that it is 180 degrees out of phase, and that if you equally mixed the - out and the + out they would cancel each other in accordance with phase cancelation theory.
are there any cool things you can do with both outputs other than silence?
maybe using both outs on both ins on the ring mod?
or creating a simple phaser with some fiendish patching
another question: what effect does the offset have on audio signals, using either - or + ouput?
thanks
