Okay, so I have a question regarding using the CP to control the Filter Cut Off on the LP. Assume my set up is the following. The Little Phatty has a preset where the FCO is at the 10 o’clock position, and the CP is plugged in to the Filter Input with Exp active a 0-4095 range which starts at zero. When I start playing where is the actual Filter Cut Off on the LP, is it 0 or is it at 10 o’clock. When I depress the pedal of course the filter opens and I assume that when I close it all the way it will close the Little Phatty’s Filter all the way too. If this is causing problems on way to fix it would be to have a preset on the CP-201 that corresponds to each preset on the LP and would keep the FCO in the proper place.
-and- this is fundamentally different that using the expression pedal with the 'foogers, am I correct, because aside from the using a MuRF, the lowest that a particular parameter goes is where it is set on the 'Fooger, is that correct?
