couple of super noob mooger questions
2 questions i know the answer of just want to be sure
my mf107 freqbox is coming without the power adapter, can I use the adapter from my MF104M , basically do all foogers use the same adapter ?
can I hook up the oscillator cv out of the freqbox into the slim phatty cv ins ? and can I hook them up to the mf104m cv ins ?
Thanks !!
The PSU should work indeed.
About the OSC OUT of the 107, isn’t it an AUDIO out?..
You can hook it up that way but it will just dirty up the sound a bit.
Env Out: Outputs the unconditioned Envelope Follower Control Voltage signal.
Osc Out: Outputs the wave-shaped VCO signal as a +/-2.5V Control Voltage signal.
These are from the specs of the freqbox and I want to use these control voltages to mess with the phatty’s and mf104m’s cv ins .
I’m pretty sure it will give some decent results , just want to be 100% sure about voltages to not overload anything , any of you guys tried something similar ?
When you connect Moog gear with other Moog gear, you are in the safe zone. If it doesn’t work you don’t get smoke, simply nothing, or poor results.
Watch the speakers & ears. Keep volume low to start.
Mind the power supplies.
