couldn't midi sync (arp / seq) the messenger with other gear
my Messenger doesn’t sync its arp nor sequencer with the tempo of my drum machine.
The other gear (Prophet 6, UBxA) midied to the Tr8s sync very well, however I’ve tried different midi settings with my Messenger. Did I miss something ?
well I’ve found the solution to sync the arp / seq to midi clock with this : 3.3 MIDI Clock
Settings Global PGM 1 = Respect Start/Stop (lit) Ignore Start/Stop (unlit)
But there’s a new problem, the Messenger is not always “in time” with the other gear : you have to be very precise when starting the arp or seq, or it will be misaligned. And with the arp (set in 1 octave) when I play a note on the Messenger it starts with the note one octave higher :open_mouth: , while I prefer it starts with the note I play
Everything works when the synth is not connected via USB or Midi. But when connected with Ableton, receiving extarnal sync and midi, the arpeggiator is unable to pay more than one note, even is i play a chord… With ARP OCT, it plays every octave possible, in any setting. The ARP is actually unusable with a Daw or sequencer, with firmware 1.0.8
