I’m probably missing something, but I’m not seeing an easy way to copy all of the internal presets on one Minitaur to another. Anyone know best way to do this so I can have a backup with the same presets?
Isn’t there a sysex “dump all” function on those bichos?
If you send this SysEx (notated in hexadecimal numbers here) to the Minitaur, it will send out all patches as SysEx:
F0 04 08 06 00 00 00 00 00 00 00 00 00 00 00 00 F7
Any suggestions on best method to send and record sysex at the same time? I’m trying to send via Max and record with Sysex librarian, but I don’t seem to be getting the message format correct in Max. Trying to use sxformat object. Maybe there is a more simple method?
Elektron C6 should help.
I built myself a very simple self made App to send out small SysEx strings. And I use SysEx Librarian on my macOS to record the received Minitaur SysEx patches.
Download and use at your own risk: https://till-kopper.de/soft/index.html#midi-sender
And as I am not a certified macOS developer (cost me too much), you will get a macOS message about telling you about this.
Thanks Till ![]()
Hey that’s cool! Thanks Till!
