What’s the easiest way to use Velocity as a volume shaper?
I mean either to control all three VCO levels or the master volume.
Delve into the menus, unless you have an Old School.
Hmm… I guess it must be the POT mapping then. I’ll dig into it, thanks.
Master volume for overall loudness. Pot map it to an individule osc and now velocity can bring in a different timbre or an osc tuned to 5th, 3rd etc. Based on your playing.
Thanks, that’s what I just found out by reading the manual. I suppose this also means I need to use two pot mappings out of the four available to replicate the same modulation control on both the Master Volume and Headphones output. Will check that as soon as my wife switches off the vacuum. It would be handy to have a double destination in this case (Master + Headphones Volume) so you just have to use one pot map for that.
