Controlling each preset's volume
Is the only way to set the volume for each preset is using the independent, each oscillator’s level ?
Any way to set the final level for each preset, to the entire sound ?
On the Little or Slim Phatty, I think there is no way to do this.
On the SubPhatty, I understood there is one: under the hood you can set whether the volume knob position is saved with a preset or not.
What a bummer ! I in some presets I must set the OSC levels to about 1 (of 10) to make them in balance with other “quiet” presets,
the sound I get when lowering the OSC levels is not similar to what I get when they are fully open…
So you wre talking of Little Phatty then.
You can consider using a volume pedal into the Volume CV input.
