Connecting sequencer to Micromoog
Hi.
I have owned a Micro Moog for years and was excited about Behringers affordable new 960 sequencer. If I wanted to connect this to my Micro Moog would I need to run an out from the sequencer into the S-trigger input? If that is correct can anyone recommend a good supplier of this cable? I’ve seen several online and most seem of the DIY variety.
The Moog and the Behringer clone 960 sequencers both got only V-trigger outs. You need to convert this V-trigger into S-trigger first. This is an easy DIY project, as this done by a single transistor. Some times, this is actually built inside a ¼" jack.
