Confirm Sub 37 OS version and Update
I have a Sub 37. Owned over 48 hours. How can I confirm the OS firmware version and update to the latest?
Press the Global button. The top line should say Global Menu 1.1. If so then you have the latest version. If not you can download from the Moog site …
http://www.moogmusic.com/products/phattys/sub-37#downloads-tab
Thank You
Hmmm. I think that “1.1” just means you’re on Global Menu page 1, item 1 :slight_smile: . But you’re on the right track. Press the Global button, then press the up or down arrow buttons that are right under the display until the top line says “Global Menu 3.x” (where x is any number). The bottom line of Global Menu page 3 shows the firmware versions for the main unit and the front panel. It’ll look like this:
M1.1.0 P1.1.0
The latest released version for both is 1.1.0.
As Bald Eagle said, if you don’t have the latest, it’s definitely worth downloading at the link he provided and installing it.
Hope this helps.
Moose
Thank You.
