Clusterflux Meaty Beat
Is it just me are doe’s this Clusterflux have a meaty’r overdrive than the other Fooger’s/
here’s and Example with no other fx, straight drum machine through Clusterflux
http://soundcloud.com/phattcharlie/fluxface
I’m currently fascinated with the this Fluxed up Fooger and have been knob twisting on it for a few day’s, stole the show away from my new Voyager XL believe it are not
Here is and ambient loop with a Novation Ultrastation running through the filter’s on a Minitaur and into the Clusterflux run into a Murf finally processed with a wacky reverb
http://soundcloud.com/phattcharlie/wishfulwisdom
I like it myself though I think the reverb may have been too much, it took away most of the panning movement of the Murf, still a work in progress
Anyway back to the question what do you think Flux overdrive as compared to other Mooger’s?
It sounds different.
I do not own one, but I can tell right off, that this sounds different than MF-101 Drive.
One thing more that I like it on Clusterflux. For me it is just to expensive.
I do not use chorus or flanger at all. I know that it is much more that that…
I have to get FreqBox and Furf first… than Phaser… Maybe one day :smiley:
Nice demos btw.
I came into bit of money and decide to set up and all moog system with as many Mooger’s as I could afford
I bought the Clusterflux last after spending almost seven hundred on the Midi Delay. The price was up there and I was considering a lot of thing’s including the minibrute at that price point I had alot of other options, I don’t regret this purchase in the least.
it is the most flexible Fooger I have sound creation wise. It work’s extremely well with the Murf my former favorite before the Cluster. I don’t have the Phaser and I’m trying to scrape together enough cash to get one, I think it is a rather important element in the Fooger line, then perhaps a CP 251, the can’t possibly afford it list go’s on…
Yup, MF-108 drive sounds different to my MF-102 drive. I do put my x0xbox through it for some mild overdrive acid lines.
I love flanger and although I don’t use chorus, I do end up using the chorus of my MF-108 from time.
Best sounding flanger I have ever heard, the Cluster Flux is.
Do you have some tracks using your midi murf?
The fulltone choralflange is pretty good 2
I have always thought my 104z has a better preamp overdrive than any other fooger I’ve used, but I haven’t tried the 108 yet.
