Should my Cluster flux level LED be lit at all if there is no audio going into it?
Cheers
Cheers
So light only flashes constantly (even with no audio being set) only while plugged into the voyager mixer out filter in, It works as normal with other bits of gear being patched into a mixer…
I started a topic here http://forum.moogmusic.com/posting.php?mode=post&f=2 in voyager forum in case it was a mixer out filter in prob…
Cheers
I play guitar but mine is only lights when i am hitting the strings. Adjust the drive so that it lights up when you send it something.
Hey, thanks for your reply.
That’s the thing, even with no drive & connected to my voyager mixer out filter in, it is lit continually…
But when I play something else through it it functions as you described.
Wow, O.K. I have no idea then, sorry. I haven’t got a synth yet. I want one and plan to buy one in the not to distant future, but I already know that I have a ton to learn just on the technical side. Sorry I couldn’t be more help.
Thats normal. The voyager mixer out always has signal present as long as the oscillators are on.
Cool ![]()
Thanks guys ![]()
