Hello,
I just realize one cares about the Minitaur click, here is my problem
I work with Cubase 7 when I made a MIDI sequence on the Minitaur and when I put the osc 1 and 2 zero I have a sort of click the midi note that is if I click the mute sequence disappears
I just try to unplug the usb and I unplugged continuous twelve o’clock taking his continuous also
so I unplugged the usb and noon and connect the Minitaur in CV / Gate with a MAQ 16/3 is still the click
I disconnect the audio output and put a helmet direct the output of the Minitaur problem is still that this is just some of the many Minitaur
is that this is normal?
Here are the settings Minitaur is what a person could replicate these settings on the Minitaur a sequence running and tell me if it encounters the same care
Setting wave
The problem is defined on the two waveforms
Setting filter
Cut = Centre
Reso = Centre
VCO tuning
VCO 1 = 0
VCO 2 = 0
Setting Env Filter
A = 0
D = Centre
S = Centre
R = 0
Setting Amp Env
A = 0
D = Centre
S = Centre
R = 0
Setting LFO
Rate = 0
VCO = 0
VCF = 0
Thank you in advance for your help
