Cleaning Minimoog pots?
Hello fellow Moogheads -
My Mini has a pitchbend that never quite makes it back to center pitch. I know of the diode mod, but where would I locate it to see if it’s been done? Is it usually in the left hand controller section?
Some of the other pots on the control panel are now intermittent. Is there a technique for cleaning these? Can they be easily disassembled for direct cleaning? I think I read once that someone drilled holes in the back of the pot to squirt a cleaner into the pot body, but I don’t want to do this for fear of ruining the pot.
Would replacing the worn pots be a better alternative, and if so, what are good modern replacements?
Thanks for any help…
