I’ve got the VX-351 working with the voyager and I can set the LFO to begin it’s cycle with each “note on”. What I’m trying to do is have the LFO from the voyager routed from the VX-351 to control the freq cutoff of the lowpass mooger fooger, but the LFO starts it’s cycle at maximum amplitude. I’d like to have the opposite occuring as in: I press the note on, and the lowpass filter freq cutoff is at it’s lowest point then the sound"opens up" as the LFO cycle reaches it’s maximum amplitude.
How can I achieve this?
Feed it through a later version CP-251 attenuator and invert the signal or change the offset using the mixer.
Unsolder one end of your patch cord and re-solder it the other way around.
Thats the only thing that I think is lacking on the 101, the abillity to dictate on that particular unit which way you want the filter to sweep via its envelopes.
