change the name of a preset
I modified a preset and then moved the modified version to another preset location and over-rode that preset. So the new preset has been successfully saved. However, I want to change the name of the preset so that I don’t have two presets of the same name. I can successfully change the name using the cursor and the +1 and -1 buttons, or the keyboard itself. However, I cannot figure out how to save the changed name. When I hit “edit” and go to “save” it reverts back to the original name and all my changes are lost. I’ve tried this multiple times and tried different things and I can’t seem to figure out what I’m doing wrong. Suggestions?
have you tried using the librarian?
I find it’s very useful for stuff like this
your problem almost sounds like some weird permissions/OS issue. how did you move the preset? I didn’t know you could do that, using the screen menu
anyway, good luck. I’m sure someone knowledgeable will chime in
