CHANGE ALL ARPEGIATOR SETTINGS AT ONCE
CRAZY QUESTION?
INSTEAD OF GOING THROUGH EACH PRESET ONE BY ONE AND CHANGING THEIR ARPEGGIATOR SETTINGS, IS THERE A WAY TO CHANGE THEM ALL GLOBALLY? I WANT THEM ALL TO TO HAVE AN LFO CLOCK SOURCE ETC.
The arp currently only has per perset settings. Hopefully in a future OS update there will be a global setting. I’d also like to be able to change presets and have the arp keep running
There must be a way to present a matrix from the bank sysex file, containing all presets (per row) and all parameters (per column). With edit and update functionality.
Can’t some programming competent person fix such a program? It would make bulk handling of parameters sooooo much easier …
Pleeeeease …
:sunglasses:
I believe the SoundTower editor can do this.
Also, OS3 for Little Phatty will allow global setting of clock source and clock divisions. Other settings (pattern, order) are still per-preset within the LP OS, but again can be edited en masse using the SoundTower editor.
Wow, relatively new LP owner here and I’d not heard of the SoundTower editor. It looks amazingly useful, and I can’t believe it’s free!
http://www.soundtower.com/moog/littlephatty/index.htm
I’ll definitely checking this out tonight. Thanks again, Amos.
