[OSX/standalone 09.28] Categories are not in sync with Sub37. In this example the synth shows categorie Bass. Imho the handling of categories is not that clear: selecting categories restricts correctly the number of entries in the preset box, but when ‘All’ is selected there is no visual clue to which category a preset belongs
I had a similar problem and it was because I still had the old category list from a previous beta version of the Editor.
The fix is to delete the file “PresetCategories.xml” which will be re-created fresh the next time you open the Editor.
To view this file, the easiest way is probably to open the editor and go to the Librarian view… right-click on any preset in the Preset Library and choose “reveal in Finder [/Explorer]”. This will take you to a (OSX) Finder or (Windows) Explorer window showing the Preset Library. Go “up” a directory or two, and you will be in the main folder for the Sub37 editor. Look for a file called PresetCategories.xml, and delete it.
If you’re having any other odd issues, like inability to connect the editor to the Sub 37, you might want to delete the .prefs files here as well. The .prefs and PresetCategories.xml will be rebuilt the next time you launch the Editor.
