I didn’t think doepfer offeres the cheapest modules.
Modular synths generally contain
Signal Generators
Signal Routers
Sound Generators
Sound Modifyers
In an analog system like these, the signals can be Control Voltages (that control things like Osc freq, Filter cutoff-parameters that are usually manually controlled by potentiometers), or Triggers/Gates (signals that tell a unit to turn on or off only (like those that fire envelope generators or start and stop sequencers).
Signal generators are things like Keyboard or other types of accessory controllers (ribbon controllers, joystick controllers) or modules like envelope generators, sample and hold (random voltage generators) or sequencers.
Signal Routers are devices that aid in programming. Modules like Multiples (multiply a signal and allows that signal to be sent to usually 4 destinations) and Attenuators (modules that reduce the strength of a signal) route signals to other destinations. Early Moog Modulars had half- sized panels on the bottom of the cabinets that were hard wired to other modules to save on patch cords and to make real-time performances easier.
Sound generators are modules like Oscillators, and noise sources.
Sound Modifyers are modules that modify sound such as filters, VCA’s and Ring modulators.
A little more in depth info:
Some modules have double functions, for instance, an oscillator can become a signal generator and some filters can become sound generators if they have that feature. Envelope generators generate a signal by modifying a signal (turning trigger signals into variable voltages) so its something that takes a long time to familliarize yourself with.
Not all companeis adhere to the same voltage standards. Most companies today produce synthesizers that respond to control voltages that are 1 volt per octave. Some old Moog stuff is Hertz per Volt, and Some are less than 1 Volt per octave.
One of the main differences between companies are the trigger voltages. Triggers turn something on or off so it might be -5v to +5v or 0v to 5v. SOme exceed these voltages. Id be doing you a disservice if I tried to tell you what exact numbers particular synths (even Moogs) use so Ill let someone else chime in.
Lots of people have “hybrid” synths that pull together modules from various companies that have the features they are looking for. Moog is famous for their filters. Doepfer has bit crushers. Dotcom has the nice sequencers. Modcan has the quantizer, Buchla has the controllers. You can pull all of these together just so long as you know that the signals are compatible and have something to MAKE them compatible if they aren’t.
A lot of people these days like the “Eurorack” type of cabinets because they think that Moog/Dotcom sized modules really are a waste of rack space. Youll need 5 rack spaces just to hold 1 oscillator. In a 19 inch rack space you can only hold 8 single sized modules. Eurorack offers more compact systems, but I am not familliar enough with Eurorack to aid you there.
If you live in NC, visit the factory in Asheville and check out the Moog Museum when they get that built.
Hope this helps you out.
My advice to you is to go to moogarchives.com, click on a module and read both the functional description and the musical application for each module. You might not understand how everything works, but as you progress in synthesis you will. Go and download a manual written by Tom Rhea and spend a lot of time reading that.
MicroMoog manual
http://www.fantasyjackpalance.com/fjp/sound/synth/synthdata/07-moog-micromoog.html
Read read read and think about what the modules do and visiualize how you would patch them together if you had them.
Synthesis is engineering, its not an art form in my personal opinion. Applying the sound is where the art comes in. It has a relatively high learning curve but once you see how everything operates then you will be able to hear a sound in your head and figure out how to get there, or you can listen to some synth on a commercial and tell exactly what they are doing to get that sound.
