Can't send new firmware
Hi, I have just got hold of a second little phatty for my set up which I am trying to do a firmware update on. I did the firmware update a few days ago on my first LP and it worked fine, but on my new one it’s not responding.
I have tried sending it using the PhattyLoader and sysex Librarian with no luck, I am using USB MIDI (but have also tried standard MIDI via a MIDI interface). What is odd though is that I am able to send presets, just not firmware.
Is there something that I am missing here??
Sam
What is the model & firmware version of the LP you are trying to upgrade?
Which firmware release are you trying to use for the upgrade?
It’s a moog little phatty stage II, running version 2.103 trying to update to the latest from moog downloads (3.1 I think)
there’s your problem. There’s a v2-to-v3 update that must be run first.
Try this:
http://www.moogconnect.net/downloads/phatty/LP_Stage_v2-v3_Update_OSX.zip (v2 to v3 update, mac version)
http://www.moogconnect.net/downloads/phatty/LP_Stage_v2-v3_Update_WIN.zip (v2 to v3 update, windows version)
read the instructions carefully; for example you might have missed the step where you go the Master menu, System Utilities, and set FW UPDATE: ON
(this is a required step if you are updating an LP SEII from firmware v2; it’s not needed once you are in firmware v3)
That is the exact answer I needed! worked perfectly, thanks
