Can't copy files with AudioCopy
Hello,
I need help to copy my audio recordings (made with the record button) with AudioCopy.
Animoog 2.3.4 opens AudioCopy automatically, then the file is copied (files were so easy to recall before) but does not appear in the Animmog file list as it normally used to do inside the pasteboard app.
I’m on ipad2 latest iOS update, working on a professional project and cannot use Animoog melodies anymore.
Anyone can help? Thanks in advance.
Hi Matgaz,
I’m not certain how you’re trying to copy a track, but here’s how it works for me:
  • In 4 Track, double tap on track and select AudioCopy
  • An AudioCopy dialog appears and you have to select ‘Copy Audio’, then select ‘Done’ (top right, might be hidden by copy notification), this brings you back to Animoog
  • Paste in your other app (I use GarageBand, paste from AudioCopy works there)
Does that help? I have stopped using AudioCopy entirely (I used it for well over 100 Animoog tracks). I now record directly in GarageBand using Inter-app audio, that’s a much simpler workflow. (but I hate that we have disable the metronome and set the length to ‘automatic’ when a new track is created on GarageBand, other than that, works flawlessly)
Hope this helped :slight_smile: – Alex / Satri
Hi Matgaz,
Thanks for your report, we’ll take a look.
Satri! i think u give a simple tutoril about copy a track.and it will be helpful for Motgaz as well as for me and for other.thanks for your help about Motgaz problem.if any one have this type of poblem then i think this tutorial will help them to solve out this type of problem :smiley: thnks
