Here is a quick rundown, about as simple as I can make it.
All sound travels in the form of waves. They have a particular shape with particular set of harmonics. How many times that wave cycles is called the Frequency.
THe Speed of the Frequency is measured in Hertz or Hz. Hz is how many times per second that wave cycles.
THe Strength of the Frequency is called Amplitude.
THe HUman ear can hear frequencies from 20 Hz to 20,000 Hz (or Kilo Hurtz or KHz) THe higher the frequency, the higher the pitch.
Now lets move on to voltages.
Voltages…
In an analog synthesizer you usually have knobs called potentiometers.
Unlike a digital synthesizer, when you turn a potentiometer, you are actually controlling the amount of electricity that is going through that circuit at a given point in time.
This is pre MIDI technology by the way.
If you have a circuit that acts in this manner, where the voltage going into it controls the amount of vibration that circuit makes, you have a Voltage COntrolled Oscillator (VCO). This is your waveshape generator. This is your sound generator. This is where Frequency and waveshapes enter the picture because this produces waveshapes.
Increasing the voltage in this type of Oscillator, increases the frequency, or pitch of the oscillator.
With Voltages, there is a voltage source and a destination. The devices you ask about have CV or Control Voltage inputs to accomodate the signal from a voltage generator.
A keyboard controller will send a voltage amount to an oscillator (like 1 volt per octave with some oscillators). This voltage from the keyboard changes the pitch of the oscillator, just as your hand physically turning the potentiometer will change the frequency. This is control voltage, an electronic hand that “turns the knob” for you.
Your Ring Modulator has voltage inputs that will allow you to connect an expression pedal that will control the Frequency, Mix, Amount or the Rate of the LFO on your Ringmod.
A VOltage Controlled Filter (VCF) acts in the same way. A Filter actually filters out the harmonics from a waveshape that an oscillator generates. a lowpass filter will allow low frequencies to pass through. This type of filter has a cutoff frequency potentiometer. Turning this knob will change the amount of high frequencies that are allowed to pass through. You can send an expression pedal to the Cutoff CV input to “turn” that potentiometer (or modulating) the cutoff frequency.
An Envelope Generator is a device that generates control voltages that evolve over a period of time. If you pluck a string, it will vibrate. it will have an Attack Decay Sustain and a Release. An Envelope Generator creates a voltage that conforms to these properties (ADSR), by putting a value to each.
A voltage controlled amplifyer (VCA) lets the sound generated by your osc to output to your speaker. Increasing and decreasing the voltages to this device will open and close the VCA, controlling your volume. A gunshot will have a very fast attack and decay, virtually no sustain with a long release as the sound dies out as the waves travel away from you. THe ocean’s surf has a slow attack and a slow release.
In summary,
If you have a device that generates voltages and has a CV OUT, hook it up to something that has a CV in, and you will have remote control over the destination normally controlled by a potentiometer.
Your LFO from your ringmod will modulate the cutoff frequency of a voltage controlled filter. If you hook that same LFO to your VCA, then it will turn up and down the volume really fast generating a tremelo effect. This is what happens to the Frequency of the Carrier Oscillator in your Ringmod when you have it switched to LO.
Any questions?
