Can pot mapping control multiple parameters?
Hey all, i was under the impression that you could assign multiple parameters to a pot, eg. cutoff and resonance and lfo rate to a pot using pot mapping, not just one parameter at a time. Did I dream this or is it actually possible?
From reading the user’s manual I don’t think it’s possible, the way I understand it. Each potentiometer can only send one MIDI CC value at a time, although it can control simultaneously the internal synth and an external one, by selecting “both” as assignment. But it will control the same thing on both instruments however.
Did I read this right ? You joined the forum in 2009 and this is your first post ? :open_mouth: Better late than never, I guess ! :smiley:
Hey, thanks for the reply - i suspected as much. Ah well, i’ll stick to sending the phatty MIDI from my DAW to control multiple parameters at once instead.
And yeah, this is rather shamefully my first post after being a member for almost 3 years, been too busy playing the moog! :smiley:
If you use something like Bomes midi translator, you can control as many parameters as you’d like from one pot. Internally, externally, etc..
