Can MF-103 Phaser used DC supply from Power Pedal2 ?
I’ll upgrade my modulation part from MM4 to MF-103.
Thank you very much
Thank you very much
Ignore this post, it seems you can’t delete posts around here.
yes you can.
I power 3…MF-101, MF-103, MF-104 all from a pedal power 2. You just have to use reverse polarity cables. The cable with the red tip that comes with the PP2 is reverse polarity.
Or you could make one. Radio Shack?
Thank you very much
