I get a buzzing noise when I connect LPII via USB to my macintosh machine. It sounds like something grounding related, but Im not sure.
Any tips to get rid of it?
I dont like the sound of vacuum cleaners…
Please help me out!
I had the same problem as you for the longest time. I can’t tell if its the Macbook or my Phatty that’s causing it, but connecting to it via USB will cause a hum to come out of the Phatty’s output.
The only advice I can offer is to switch to a standard MIDI/DIN plug:
instead of USB. I switched to a DIN plug and haven’t gotten any noise since.
EDIT: For what it’s worth, I did happen to notice that when my macbook was unplugged the noise would go away.
I have this problem too.
I just got my Phatty upgraded to the full stage II specs @ the factory (+CV output mod).
When I connect it to my Mac Pro via USB, I get low hum+ hi pitched whine in my audio path.
The noise goes away if I revert to normal MIDI cables.
Has anyone noticed any MIDI performance difference between MIDI via USB and normal 5 pin DIN MIDI?
Particularly with regard to recording/playing back 14 bit automation?
Seriously, I have Mesa Bass Amp that has a ground loop switch on the back; it does magical and wondrous things but I never opened it up to see what it’s actually doing? Perhaps just dropping ground from some part of the circuit?
But I had a Matrix 6r that, depending on where I plugged it in was absolutely horrible. So I wired in simple switch, problem solved. Was always concerned about lightning (literally) striking and frying something; we get pretty bad thunderstorms where I live and the power quality is not very good.
In this case though, great to see a fix for so many! That thread is a good read.
UPDATE
My Phatty was plugged into a Dlink USB hub.
When I plugged it directly into the Mac Pro on the front panel the problem seemed to go away, or at least be seriously reduced.
