Congratulations,you’ll really enjoy it
. Midi’d with other synths you can get some great textures, I used to MIDI mine with a DX7 all the time. Right now mine are in need of repair and calibration. One day
In case you don’t know the Plus had real early MIDI, it will only transmit and receive in omni mode, you can get a MIDI filter though. The Sequencer can be fun, limited but fun. Also the Arpegiator is a lot of fun to play with.
As you’re finding out you can do really nice pads, bass, leads, effects… for fun come up with a patch, put the MM in Mono mode, and chose to have all six cards playing, that will give you 18 oscillators on one key, you can of course thin it out to just one or two cards.
Experiment with the different assign modes,cyclic chose’s a new card each time you press a key, for example if you hit C3 six times in cyclic it will use card A the first time, Card B the Second, Card C the third… there will be slight variations with each key press.
Also in case you haven’t noticed on OSC1, 2 and 3 you can press one, two or all three of the Wave forms to create a more complex sound.
If you don’t have them try and get a voltage control pedal, the one Moog Sells on their web site should work. The pedals give you a lot of creative options, filter sweep with one, modulation with the other… foot switches work well to, especially when hooked up to the release jack, and glide.
Do you know if it has the original “factory patches” ?
If so #21 is a fantastic string pad, very warm and full. If not they should be available on patch sheets ( all were printed in the back of the manual) or may be available on tape back-up.
While not identical, the Memory is like a Model D, only with a lot more modulation capability thrown in
. Moog even had an add in the early 80’s (US) with the MemoryMoog pictured in the center with six Mini’s surrounding it.
Have Fun
Brian
