In a standard mult such as the pair inside of the VX-351 or on a modular synthesizer, the tip and sleeve is simply connected across each of the four jacks. It’s literally just 4 jacks and wire. So if you connect a powered jack with +3V in any of the four jacks, that voltage will show up in the other 3.
I believe the CP-251 is identical with the exception that the red or circled jack has a 3 conductor jack (TRS) and the ring has +5V on it with the idea being that if you plug in an expression pedal (and for your information all that passive Moog type expression pedals do is attenuate the voltage from heel to toe and return the attenuated voltage on the tip of the plug), the 2.5V or 1.1V or whatever (up to the original +5V) is sent to the other 3 jacks on the Tip of jack #1.
I’m not sure if there is any diode protection to prevent voltage from other sources to going to jack #1 or not. I doubt it.
But if you take the Mod wheel output of your VX-351 and plug it into Jack #2 of a Mult and take an output voltage of the touch pad into Jack #3 of the mult then take a patch cable from Jack #4 and plug it into your a Filter Cutoff on your Voyager; with the Mod wheel fully up and the touchpad position fully on (e.g., either up or to the right), you’ll have +10V heading into the Voyager. If you do the same on the CP-251 and then plug an expression pedal into Jack #1 and put it to TOE with the trim attenuator all the way open (CCW), you can have +15V arriving at your Voyager. Will that blow something up? Hope not, don’t think so, but it’s not advisable.
If you were to Mix these instead and possibly had an LFO as one of the sources, you could have some combination of voltages which might be interesting from a performance point of view and you would be assured that you would not exceed the max of any one; the mixer ought to max out at unity. Some mixers, however will actually BOOST. They have gain in the channel, or an overdrive which in some cases is desirable (in the case of audio signals of waveforms which are pushed up to the voltage rails to create waveform distortion; such is common on the Moog Modulars and to some extent on some of the modules sold today; on particular Mixer module which is based on the Moog CP3 design is calibrated to hit unity at the 2 o’clock position). Have a read here, just out of interest. This particular mixer also has capabilities to ADD or SUBTRACT a given amount of voltage to the mix on normalled jacks [e.g. only if nothing is plugged in] - http://stgsoundlabs.com/products/mixer_mu.htm
I’ve used Mults to add voltages in interesting ways for instance, to take Keyboard CV Pitch + Mod wheel output properly attenuated to offset/transpose. The important thing is to take Moog’s recommendations on what max voltage you should keep an eye out for and certain to get a Volt meter so that you can read where things sit as you experiment until you get comfortable.
Important to note that voltages are also added within the voyager, for instance if you set an LFO with a destination of OSC3 wave, but set the wave of OSC3 to pulse width towards the higher end of the potentiometer (near full CW) in order to do some pulse width modulation, you might end up pushing the circuit beyond limits in which case you will hear a dropout of the oscillator frequency (dead spot). Likewise, voltage into the Filter cutoff jack is ‘added’ to the position of the cutoff potentiometer and that which might be added via Modulation bus routing. From that standpoint, it will be the net effect of having the Filter cutoff FULLY open and beyond the range of the pot on the panel. Whether or not this is safely limited within the Voyager circuitry is another matter; I would think so, else you would see many folks with lots of issues but I have not seen this documented;
As I said in my prior message, many of these components are rated at 16V, 25V or higher so it will not have a useful effect in the audio realm but might not be detrimental to the electronics. Even diodes which are meant to protect against current flow in the incorrect direction (and polarized caps for that matter) have ‘breakdown’ voltage and will eventually pop (smoke). But to give two examples of the type of components you are likely to see on the Voyager analog board: A 1N4001E-E3/73 diode is rated with a peak reverse voltage of 50V and a standard 1% tolerance metal film resistor is rated at hundreds of volts. It’s really the ICs and the capacitors that you need to watch out for.
FWIW, the output adapter that you installed with the VX-351 contains a resistor network (e.g., a pair of components each of which act as a single resister for a signal); this is required for the Voyager, but not so for the Voyager Old School. I remember looking up the value/tolerances of the component a few years ago and I thought I took a picture of it but it doesn’t spring to mind now.
At this point, I’m talking in circles
happy to continue the dialog but I think you have plenty to go on. Give Andy Hughes a call @ P: (828) 251.0090 ext. 221 and explain what you’ve experienced. He’s a really good guy so can answer any questions you might have. I’m just a customer with more gear and spare time than talent.
