bugs
latest firmware, v1.1.14
mac os x 10.11.2
ableton live beta 9.5.1b6 64bit
in the editor with mouse interaction:
– if i point a knob in the editor long enough to make the value mouse hint visible and move than very quickly to a other knob and click and drag, the mouse hint stays at the first knob while showing the values from the current knob i’m changing.
automation bug:
  • i setup the filter cutoff as device paramter automation control. when i interact within ableton changing the device automation fader or draging the cutoff knob from the sub editor the config is working and sync and changing togehter. if i move the cutoff knob at the hardware the sub editor knob represensation is moving but the ableton device paramter isn’t moving anymore. (device setup shot attached)
  • recording the filter cutoff within a note clip as midi cc is no problem.
graphic bug:
  • if i collaps the sub editor with the grey button on the bottom and then refold the big view there are wrong drawings on the gui. (shot attached)
  1. It’s improved on 0.9.30, can you recheck ?
  2. Will check.
  3. Reported.
Thanks !
  1. testing with v30
  1. having the value overlay bug also consistently with editor v30. also: when provoking the overlay, keeping the mouse in place and turning the related hardware knob, die overlay value does not change accordingly.
Interesting point.
I don’t think it’s ever been developed and I will add this as a feature request,
Thanks !
