They are good stands. I have used them in the past for 61 key kbrds. I imagine it should fit a Sub 37 just fine. I currently use this On Stage Stand: On-Stage Stands KS8290 Lok-Tight Pro Single-X ERGO-LOK
Howdy… I use a similar Z type stand: On Stage KS7350 Pro Heavy Duty Folding Z Keyboard Stand. It is extremely sturdy and is adjustable so the width fits inside the rubber feet of my sub 37. I would recommend this type of stand
I have both my Kronos and Sub 37 on Z stands. I play seated. I have never liked X stands - find they bounce too much. The Z stand I have for the Sub 37 is a permanent style Z that I got for about $50 - I think presonus, and it’s solid a a rock.
I think the main questions are:
do you play standing or seated? (If I was standing, I’d go spider)
do you have to break down the gear to gig, or is it relatively permanent? (Breakdown, I’d go hercules Z)
do you need tiers? (spider again)
How much will you spend? (At some price point, it is better to go modular)
I play seated, its never used to gig, I don’t need tiers as its my only synth, nothing too pricey but good quality within reason… (what are modular options?)
By modular, I meant the kind (like Gibraltar) where you build your own configuration out of their tubes, and various connectors. You order the pieces you need and they all go together. Not at all portable and a bit expensive. Popular amongst drummers, but you can usually order keyboard configurations too. I thought about doing it, but my Hercules Z is fine considering price.
Those Gibraltar components look interesting. I’ve been looking for a dual tier stand for my Sub 37 and Sub P that will fit in the corner. Building my own may be the best way to go.
I bought a Gator Frameworks heavy duty table stand for sitting at. Then I build a custom shelf to sit on top which houses the Sub 37 which has an angled top shelf above to hold pedals and drum machine. Really nice having the other gear close by but it’s a studio only setup.
Nice job. One tier is enough for me at the moment but now I am thinking if I need to expand more maybe I could add a third tier on
I did also build a second shelf recently for my Pro 2 which has an empty second tier at the moment.
