Beatstep pro and Moog modular
Hi all - I know this is an issue that’s come up before, but many of the posts I’ve read on here and elsewhere are pre-BSP firmware 2.0.
I will soon add the mother 32 and subharmonicon to complete the trifecta with the DFAM. I also have an Arturia Beatstep Pro and a DrumBrute Impact.
The potential of this setup is exciting, but I want to make sure I’m taking care to configure the CV correctly. I’m new to CV, so please dumb it down for me if you can.
I’ve set the DrumBrute and BSP’s clock to 1P (I plan on using the BSP as the master clock, but I’d like the flexibility to use any of these device’s clocks to control.)
The BSP is more complicated. For the sequencer’s gates, I have the option of S-trig and V-trig. Which should I choose (and why, if you feel like educating a novice)?
For the pitch CV out, I have the choice of V/Oct or Hz/Volt. I assume V/Oct is correct? Then I can choose the 0V MIDI Note for each of the sequencer. Should I choose C-4?
Thanks in advance for your help!
EDIT: Also, is there anything I need to do with any of the Moog instruments to prepare for this harmonization?
In case someone else has a similar question, I also contacted Arturia and this was their response:
“You need to use a Scaler/OFFSet device or module, like the following:
https://www.modulargrid.net/e/syinsi-cv-scale-offset
