I’ve just powered up a Roland SPD-11, and the drummer was very pleased to find that his acoustic bass drum can trigger the samples with just a microphone.
So we’re getting some nice boomy kicks, but I am a little bit of a purist, and would like to use an analog sound. We have a Voyager, which obviously does excellent bass drums, but it would seem a little OTT to use it for just this purpose. We also tried the MAM ADX-1, but he said the sounds seemed a little too “housey.” (Would a compressor fatten up the kicks?)
I have thought about getting a nice analog drum machine, e.g. X0X, but we really only want the bass drum sounds.
So really, the two options would be 1) a cheap monosynth, dedicated to bass drums, or 2) a module e.g. Analogue Solutions’ BD88. Has anyone had any experience with any cheap-ish synths or modules that make great sounds? MIDI would help, but isn’t nesassary.
Finally, it might just be me, but analog bass drums usually sound wierd, whereas sampled bass drums tend to be more boomy and sub-ish. Is that something I need to get used to?
i agree that a sampler would be best. it would be a shame to tie up an analog monosynth on JUST a bass drum sound when you could load up a sampler with a whole bank of bass drums (sampled from your voyager) and other sounds too, for a very nice price.
mini
Cheers Oyster, the MBase-01 looks pretty good, I’ll just have to find one. I’d rather not sample, but perhaps a mix of analog and digital might work the best.
Thanks for that info MC , any ideas on analog bass drum sounds
i love this small machine and think that it is worth every cent, for a real analog Bassdrum it is NOT expencieve and work also with a microphone as trigger.
Fact is, that i own also the XBase09 and Xbase999, but not sell the MBase!
Very flexible and deep…
I have one of those MFB 502s. Incredibly small and easy to use. The drums are kind of early sounding. Think CR-78 and those old preset boxes, though patterns are of course programmable. Not like Roland XOX or Jomox (I have an Air Base 99).
I’ve got an Analogue Solutions Concussor BD99. It sounds great to me. If you can power and trigger it with what you have (many people probably would need to spend a fair amount to do that) then it’s by far the cheapest new option for a really solid sound.
This is absolutely true, and something I’ve gotten so used to that I can usually spot a sampled analog kick. Sampling captures those subsonic and attack-like frequencies that seem to lose impact when they’re just triggered straight from the synth over and over.
Neverthless, I’ve come up with some insanely powerful kicks without sampling. Resonance full up, cutoff completely down, and then it’s simply a matter of adjusting the envelopes until you get the desired effect. The smallest adjustments can make a huge difference, though, and make sure you test things out in a lot of different systems. Something that sounds good in the studio might not translate well in other places…too much low end, not enough attack or mids/highs, etc. A good preamp and compression is always the ideal, as well.
I just got an MBase-01 from Germany via a visiting Uncle. It is the new, blackface version (which looks much cooler IMO) released only a few weeks ago. And the SOUND IS INCREDIBLE! So deep, down to 10 Hz, I belive. 808, 909, synthy, realish, you name it. Things start getting freaky with a few LFO waveforms (which can sync to MIDI clock) and it can play three octaves of fat bass (no sustain, though).
The serial number is 606, which is kinda cool too.
So thanks for recommending the MBase; I’m gonna go and throw the SPD-11 off a 17-storey building!
