automation with midi cc ignored quite often
Hi!
I just managed to get the miniature running with the plugin in live.
Everything good so far.
Now when I have a bassline going the miniature completely ignores midi cc sent by live.
I didn’t test all cc’s in fact just vcf attack but it really doesn’t work properly.
When automating the attack time I would say about 10% of the time the miniatur reacts to it.
I thought it might be the fault of live sending the cc after the note on so I moved the automation a bit to the left but it didn’t get any better.
Live is getting midi through the usb port (not possible to use the editor with midi io) and I also tried with my octatrack sending cc and had the same problem. the attack time can be set absolutely fine using the hardware.
Any ideas?
Jens
