Using version 0.9.42
A couple of outstanding issues on the buttons. Some buttons that select a value (rather than on/off) record incorrect values in Logic X automation:
SLOPE
The 12dB slope value is recorded incorrectly - a value of 33 is recorded but it needs at least a value of 34 to change from 6 to 12 dB on mine - maybe make the margins wider rather than using exact mathematical divisions. (it should make no difference if it records value of 40 as it will still step up the slope values.
ARP RANGE
This is the same for Arp Rage: starting at arp range 0 then clicking down then up gives a value of 33 recorded for a range of -1, but playing this backs gives a range of -2. the value needed for -1 is again 34 on mine. Stepping through the values in record mode therefore misses -1.
Mod Dest values all appear to change the destinations OK.
