"Automation" problem LP
Hello everyone my name is Sam, I recently invested in a LP and currently learning very much about it.
Everything is up and running in my DAW(FL Studio 10) but there is one problem for the moment.
Every time I press play/stop in my sequencer the MODULATION AMOUNT automatically changes to the 2nd led starting from the left.
Also when I change the parameters from the OSC2 Freq button via the OSCILLATORS knob it automatically changes to the 12 o’clock led(again when I press play/stop).
Hope someone can/wants to help me, I’d appreciate it!
Greetings,
Sam
I’d help you if I could…It sounds as though your DAW outputs the midi parameters that change the LP when it sees the Play command. I’d venture to guess that the problem resides in your DAW; the LP shouldn’t change unless it is told to change…
Just a guess.
Hope this helps…
synthguy1
That’s what I first tought also.
If I find the problem i’ll post something here…
Ty for the reply!
For some reason (resolution probably), Moog chose a number of non-standard CCs for the various parameters and you may be getting bit by these. Go check the CC list in the manual and see what CCs relate to the parameters you see getting changed. That should help tracking it down.
Check to see if you have parameter chasing or parameter resetting turned on in FL (not sure exactly what FL would call it)…most DAWs have this feature so when you fast forward or rewind, controllers are properly updated. My guess is that FL is setting some CCs to defaults when you start playback.
