Automation problem DAW+SUB37
I have question to You Guys about automation in DAW (Ableton9) with Sub 37. My ableton is sending midi notes to my Sub 37 & when I press record button to record automation in my DAW by twisting one knob, for example cutoff - everything’s allright, but when I want to add ANOTHER AUTOMATION for eaxample resonance then the earlier automation is gone :frowning: Is it the fault of my Moog or just a problem that will be solved in the next software updates, what do You think? I would be very grateful if anyone could test it on his sub 37. I had no such problems with my sub phatty.
