Hi, I really wonder why this is working in Your Logic X. I have try this many times and posted this issue in the beta forum more then 1 time. But got no response from someone. And now you are telling that you can record the button movements using the editor. I really like to know How you have done this.
Thanks for this info. now I know that I have a problem in my system and not the editor.
Could be all so easy when the communication in this forum is running well.
Apologies if I’m going to a very basic level, but just in case there’s something you’ve missed…
set up a software instrument channel and add the editor as an audio FX
add an external MIDI channel with the Sub37 port (I’m using USB)
set automation to either ‘touch’ or ‘latch’ on then instrument channel
press play
twiddle some knobs !
set automation to read (or you’ll record everything you touch on the editor!)
Works really well here.
I think when I first tried I was trying to record movement on the MIDI channel, rather than use automation. Maybe this is the issue. i.e. don’t record automation within the external MIDI channel as you would for a normal MIDI instrument, which may seem the obvious route. I use the software instrument for automation, with the standard MIDI notes on the external MIDI channel.
Thanks for that. I’ve had a play and managed to do it on one channel in Logic X using the external instrument plug-in option when creating the track. It appeared to have a MIDI loop at first, but it was receiving a continuous controller message for 116 - Osc 2 level. Simply twisting the knob fixed the issue. I’m not sure if it’s as stable yet as I’ve not used it enough, but its a nice step forward. Thanks for the tip.
